| We removed the JD yield monitor from our 9650 combine and replaced it with AgLeader Insight and Trimble Autopilot. The JD monitor was OK but the AgLeader is much better. The AgLeader support is great. When you call AgLeader support you get your questions answered and your problems fixed. With JD you have to call the dealer and then he sends in a DTAC case and when the dealer gets the answer back he will call you. When you only have to work with one person to get anything fixed, I have found that it is always faster and easer. Trimble is much like JD.
Good Luck. | |
