| Can't help with the track machines, but I bought an SV250 four years ago. The Alpha series is not recommended on here, but mainly due to problems with the wiring if you have the electric pilot controls. Mine does not. 1000 hours when I bought it, now at 1500 hours, really only problem was a gasket leaking between the engine oil cooler, causing the antifreeze to get enough contamination to discolor it. Very quiet, roomy cab, powerful. Id buy another. Mine is a 2014, no def but does regenerate. | |
