Posted 8/15/2022 04:52 (#9797388) Subject: Case 3950 disk bearing caps on main frame axle.
NEMO
I need the pieces that hold the 4 inch tube that rotates and lifts disk up and are mounted to the frame. I think they are called bearing caps. There are two pieces per side and have a grease zerk. They can have 3/4 or 7/8 bolt holes . Local caseih dealer wants a small fortune for new ones. Thanks
