Swaledale, IA | When I owned a restaurant we had to glue those edges to sides of table. I am drawing blank as to what it is called but you apply to both sides then put them together but once they touch they cannot be moved or removed. If using a Formica type edge also run a chamfer bit over the edge with a small router after done.
I remembered what to use "contact cement"
Edited by hydro70guy 8/13/2022 19:42
