Search Forums | Classifieds (59) | Skins | Language
Ag leader frustration
c_mayer
Posted 8/4/2022 10:15 (#9780075 - in reply to #9780071)
Subject: RE: Ag leader frustration
c_mayer - 8/4/2022 11:13
AutosteerAaron - 8/4/2022 10:58
I've seen this happen a couple times, not too terribly often though. One trick I've found is to reload that line and it should work fine. I think it's a firmware glitch. Have you tried using SmartPath in these situations? Most guys love SmartPath.
Yes, Use SmartPath.
Unless you are trying to save the line for year on year use, the adaptive curve is a screwy thing normally. Even if you are trying to save the lines, you should be able to save the SmartPath swath for the future. I think, been a minute since I was in the planter tractor.
Also, if it's trying to make the line over there, are you sure all the implement and vehicle offsets are correct?
Chris
Edited by c_mayer 8/4/2022 10:15
