Search Forums | Classifieds (43) | Skins | Language
Fmx Field IQ sprayer settings
Fingers77
Posted 8/2/2022 19:49 (#9777752 - in reply to #9777690)
Subject: RE: Fmx Field IQ sprayer settings
The first thing to check is on the run screen and on your 4 switchbox that it's running in automatic for section control.
Next, check is in the drive settings to make sure that you have the proper valve selected for the main flow control. Make sure it's set for a fast valve or not if you have one, if FIQ is controlling the pump, nevermind.
Third, check your section settings. Make sure there is or is not the latentcy you want. If it's turning the section valves off late, up the time it shuts the valves off early. There is ALSO a setting (I always forget where) that you can set it to turn on or off a set distance from a boundary or such. I usually set those distances to zero and control valve overlap with the valve timing.
Did you write all of your 750 settings for these things and enter them in the FM in the same places?
What correction source are you running? Is the satellite in the upper left of the run screen grey when spraying?
