Ontario | you wont be able to directly import the shp files to those displays in that format. Those lines could be converted to guidance lines to appear in the display or boundary lines and then imported into the display for viewing but unless you are running RTK or similar signal, you won't be perfectly accurate.
I work for a company called Deveron, working with farmers on data management and planning. I have helped some people load those lines on their phones for easy viewing vs the displays since they were never originally designed for that work. | |
