Posted 6/23/2022 23:34 (#9718533 - in reply to #9718331) Subject: RE: New Holland round baler, what causes this?
Might be slipping the clutch on the sledge roll drive, was a common issue in grass hay on older machines. Usually tightening the slip clutch a flat or two on the bolts would cure them, not sure if they still use the same clutch.
