NE part of SW Iowa | This year, I was dropping in population (intermittently), also; on a JD7200 ground driven 8 row rigid frame planter (wing fold).
It affected the WHOLE planter, I got out and starting feeling bearings "for heat" = first bearing, I grabbed, was very warm = to the right side(standing in front of planter) of one-way clutch, under main frame = the one that disconnects, when you raise the planter, with the lift module wheel frames.
When I went to disassemble, I saw I had a "misalignmnet problem", between the 7/8" hex shaft (from wheel modules) to the round shaft, that drives the one-way clutch assembly = that caused that flange bearing to go out; thus with that bearing failing and getting rough spots, inside of it, it would "lock-up", thus making one-way sprag clutch slip. I only had 10 acres left, so I got some chain lube, and squirted it in that failing bearing, and did this ever 2 rounds, and Population went right back to normal, and stayed there.
I had to get this repaired quickly, as a hail storm ruined my soybeans, and had to replant = replant went fine, for Population stability, after new bearings, realigned, and new sprag one-way clutch, too.
Edit: unsure if a 1770, uses the same type of clutch mechanism, or not.
Edited by 4WD 6/23/2022 13:06
