Search Forums | Classifieds (5) | Skins | Language
FMX not seeing Autopilot Magnum
Fingers77
Posted 5/18/2022 21:12 (#9665861 - in reply to #9665772)
Subject: RE: FMX not seeing Autopilot Magnum
When trying to connect to the AP, no because it wants to run the signal through that first.
When I am running manual guidance, yes it works fine, it will converge as expected, so I KNOW it is a communication issue between the AP and the FM.
Is the idiot light flashing on the autopilot rapidly?
Is the Autopilot Lockout switch off, as in not locked out?
If you are running an AutoPilot, try removing the Autopilot plugin and load the manual guidance plugin. Then confirm GPS settings, THEN see if you do indeed get a signal. That will help you narrow it down.
