| As busted piston circled we replace ours quite frequently have to take detent cover and and cable loose about a 45 min job on and off total. There is a plug behind the cover that screws into stack. Oring on that. Then once together set desired flow and adjust screw on detent should solve problem. We run a vac bulk fill planter and about once a yr have to fix that because oil gets so hot | |
