SD | Installed Trimble autopilot in a JD 8200.
CFX 750 Ver 7.8
Nav II Ver 13.75
Hydraulic steering
Installed this a week ago and calibrated. Everything worked good. Just running WAAS
Got a different planter
CaseIH 1250 16 row 30” Front fold
Pro600-only used for hydraulic functions-Vac fan, bulk fill, and planter fold/markers
20/20 Gen 2 w/IPad
SRM based
Delta Force
V Set Select
Flow sense
Clean sweep
Hooked up planter. Installed 20/20 and Pro 600. Running GPS from Nav II to 20/20. Don’t need gps for Pro600 for what I am using it for.
Took to the field to adjust shutoffs. Got all of that working good. Set AB line and tried to engage autopilot. 750 shows autopilot not allowed. Faults none. At bottom of screen get message “Can’t engage-unknown reason”
Sometimes says autopilot ok but only for a second and then says can’t engage. When turning the wheel message says manual override detected. Do not have remote engage switch yet-just using screen to engage.
Kind of hard to diagnose a fault when all it says is unknown reason. Have not hooked up AP toolbox yet to check for faults there.
Was maybe questioning a hydraulic issue with everything running for the planter so shut that all off and still same thing.
Any ideas?
Thanks!
