Posted 5/9/2022 17:14 (#9654132 - in reply to #9653658) Subject: RE: Getting field boundaries into Gen 3 20/20
NE South Dakota Clark, SD
2020 just needs shapefile format and you should be able to download from Ops Center. You will need .shp .shx and .dbf. They should be named as the field name so it is easy to get them applied to the correct field.
