Near Intersection of I-35 & I-90 Southern Mn. | Another thought. The advanced seed information that you seem to have lost is only available for corn NOT soybeans. If you entered a new corn variety as soybeans when it should have been corn, the advanced information will not be available.
I have done this. It is easy to do as the crop type defaults to soybeans as I recall. If you don't change it to corn, your new corn variety is considered soybeans. Since you are "starting over" in a sense with the InCommand this could have happened to you also. Check the crop variety type of that variety you were using to see if it is correct within the InCommand.
Edited by tedbear 5/9/2022 06:51
