| Depends what display you have and how your planter is setup. I do believe you will need a rate controller if you have a 2600 and possibly not with a 2630 since it has a task controller. John Deere did make a harness to hook into a Kinze half width disconnect PF90620, but not sure exactly how you tie it in. I would call AgExpress and I'm sure they can guide you through what harness you need based on your planter config and display. They can also probably make it cheaper than Deere. | |
