NE Indiana | Since you have an incommand do an update to the latest firmware and you won't have to do anything other than be logging coverage for SmartPath to work. Once you open a field it will ask you guidance width and then it automatically starts off with SmartPath loaded. Very handy for doing endows as I always forget to start a SmartPath when I do them
Also on your second picture the reason it isn't creating a coverage map is because you have the rate set to 0. Has to be something put in there.
Edited by kgbarnett22 5/6/2022 13:02
