NC Iowa | Glide would be worth it more than guide. Guide works fine up to a certain speed but that’s it.
Honestly best thing would be having a second setup for the ydrop…something like a nitrogen bar. Keep the weight off the sprayer booms.
Rates vary on fungicide..sometimes 15 gpa sometimes up to 20 gpa. I’d say minimum is 15 gpa.
Start time is up to you.
Scoop mine has it others around don’t. Helps divert tassel upwards when fan reverse is kicked in but that’s it. | |
