Clinton County, Michigan | I don't know if there is an general consensus that will be true of all RTK Float. I would ask why RTK Float is the best accuracy the receiver is getting (and not getting RTK Fix)? This could be caused by a bad antenna, tree cover, or only using single frequency (L1) instead of dual L1/L2.
Generally RTK Float should be more accurate than WAAS, but probably not better than 20cm, and will not have the repeatability of RTK Fix. | |
