Near Intersection of I-35 & I-90 Southern Mn. | The InCommand has a headland feature so you could plant them last. I have never used it. I believe their assumption is that you would be using the same tractor and planter to plant the headlands last. Hopefully someone will chime in that uses the feature, I would think it would be better if the headland planter was the same width as the other planter. Maybe that is not a problem.
Edited by tedbear 5/1/2022 13:05
