gpsdude - 4/30/2022 15:49 Keep it under 5000 polygons and you will be fine. Field size can also make a difference as the number of vertices also adds up. I typically use 1000 seed breaks and a contour polygon vs shape grid.
Are you talking 5000/field file or 5000 total? 5000/field file would be crazy
I suppose you could get to 5000 total loaded on the screen if you farmed a lot of acres with a lot of variable soils but that still would take some extreme prescription writing.
