Butterfield, MN | You don't mention the model of sprayer, but some of them come wired up for fence row nozzles whether or not they're installed, so they use the same harnessing, and they get set up this way. You're probably going to want to set it up for 7 sections with section 1 being set up with either 0 or a very small width entered in. Then everything else can be set up after that as makes sense, 2 being the width of 1, 3 being the width of 2, and so forth. | |
