Near Intersection of I-35 & I-90 Southern Mn. | That would certainly be a problem. KZ has different wiring patterns, this is the last portion of the model number. Be certain that the part number and wiring are the same as your other set. Using a control valve where an ON/OFF valve is needed will produce some strange results.
The valves have internal limit switches to stop them from going round and round. There is one for Open and another for Closed. Something with the limit switches or maybe the ball itself is not right. I vaguely remember a ball valve where something like that could happen with improper reassembly.
Edited by tedbear 4/26/2022 06:48
