SEIA | Had good luck steering with number of X30 Topcon units, even better luck if swapped out for X25/X35 monitors. If it's the small non-touchscreen GX-45 or C1000...ehh not so much. They do work but are not overly user friendly. C1000 is fine for tractor controls and headland management--just not great for steering. Have only been around GX-45's (yellow box) a few times. Can't say a whole lot about them.
Also depends on which receiver is on top of cab. If it's yellow and looks like a giant mushroom it's an AGI-3. They work good, but are getting long in the tooth. AGI-4's are white or gray colored. They are an expensive receiver because the steering controller is built into them instead of being a node mounted inside the cab. Some AGI-4's are also getting up there in age.
Could answer more questions if you have. Email in profile. | |
