Near Intersection of I-35 & I-90 Southern Mn. | Yes, this is true. You may need the Ag Leader Null Modem gender changer as well. Since Ag Leader has power and ground on the their plug to power a GPS system this might conflict with your 750 since it is already powered. To be safe when using a generic gender changer null modem, I clip off all pins except for 2,3 & 5.
I did this for a few years which worked fine. You need to go into the menu on the 750 and set the GPS output correctly for the Ag Leader, Seems like the GGA and VTG messages are all that is needed. Extra messages seem to bog down the old PF3000 when I used a 750 with it. The Integra can probably tolerate "too much information" better. |
