Eastern Nebraska | If you're referring to the global.ver file, you can copy that and use that from any other export of your Deere data. I keep a copy of that file on my desktop just in case I run into the situation where it's missing.
Now, regarding getting your data into SMS. Do you have a copy of the raw export from the display or was the data sent wirelessly to Op Center? If sent wirelessly, you can go to the files section, select the files and then download them to the JD Data Manager, which helps to unzip the files correctly so you can read them into SMS, or you can download them as a .zip and unzip it yourself. | |
