ISX question
Shimmy1
Posted 1/14/2022 23:45 (#9440731)
Subject: ISX question
Central ND
Has anyone had issues with repeated air governor failure? Works fine for a month, then it starts appearing you have an air leak, then you start hearing the purge valve on the air dryer flutter when it tries to build air if you are pulling a hill, eventually it won't hold air for more than 30-60 seconds without kicking in again. New air dryer (AD-9). Is it just really crappy air governors, or is boost pressure forcing its way through the compressor when it's kicked out?
