Central ND | csb - 10/17/2021 21:02
Have to take some test plots out in field I have started to harvest. How do I keep the data for each test strip separate and keep the running bushels for the field? First year with this monitor.
Like the other reply said, just do a new task for each test plot and name them whatever you need. Then when you go to the main screen you should be able to go to the performance section, select the field and all tasks and view a total amount of bushels. I don't have the monitor in front of me right now so I can't remember it exactly.
I actually run the Intelliview version of the Pro 600 but it should be all the same menus. |
