E.Central MN | Depending on what it is, it would likely be easier with a semi that has a tow hitch. One issue will be what shape are the tires on the item being towed. Blow a tire out somewhere along the way and you've just tacked on a lot of extra time and expense. A friend of ours hauls equipment back and forth in several Midwest states, tries to put loads and back hauls together so he doesn't have to run very far empty. That's the only way it can be done at a reasonable price. | |
