Search Forums | Classifieds (79) | Skins | Language
Pivot end gun valves not shutting off
Hunter Kittredge
Posted 10/17/2021 10:07 (#9273399)
Subject: Pivot end gun valves not shutting off
Oregon
Have a couple pivots with end guns that aren’t shutting off in the positions I have them set to. Pivot position is correct so it’s nothing to do with collecting ring or anything. I’m assuming valves could be bad. How do I check it? Also need to check and make sure the 1/8 plastic lines didn’t freeze or cause any problems. The one vale is pretty old but on the other pivot I have two individual end gun shut offs that aren’t very old, and both won’t shut of now. Also on the sr100 gun when I turn off endgun from AgSense, it seems to slow down flow but doesn’t completely shut off. Thanks for any input
