Morris, IL | I don’t think 41 running amps is correct. That’s a 10hp motor but they rate them for more because they are air cooled so it can run like a 15hp and pull 57 amps. I think the 41 is if motor wasn’t used air over.
The load still depends how much the axial blade is pulling to keep it turning. Yes all confusing and very hard too really figure. Maybe 45 knows more about this. Amps is still somewhat related to load. If you stick a 2x4 in the blade it’s going to pull more vs if fan was in wide open air not connected to bin.
Yes I think 200amps will run all 3 three. I get no 3 phase for what that site does probably not needed just my preference.
Edited by NEILFarmer 10/16/2021 20:05
