Outagamie County WI | He did replace the tapered hub not the bolts which helped but it will still walk on the hills when the feeder house is feeding heavy on one side. His engineering prevents it from cutting a hole in the guard on the opposite side and let’s you know you need to move it back. You still have to keep an eye on it. If you’re running on the flat it stays in place pretty well. You are doing nothing wrong | |
