Posted 10/14/2021 19:49 (#9269188 - in reply to #9268903) Subject: RE: Gleaner Unload Auger Clutch Issues
NE WI
Does that use a slip ring to power the coil? Take the brushes out and check to see if there isn’t a ridge sticking out preventing contact with the center armature. I had to file the ridge off the brushes on our M3 separator clutch slip ring. Intermittent operation.
