| The light and buzzer comes on and stays on most of the time when I turn the lights on. Sometimes it stays on, sometimes in only comes on when the head is raised or the unload auger swings around. I have put new batters, new alternator, new circuit breakers, cleaned the bus bar that holds the circuit breakers. Made sure the alternator belt is tight, cleaned all of the grounds. Have run out of things to try. The JD dealership have checked it several times can't find anything. I saw someone else had the same sort of problems. I would be most appreciative of any help! | |
