North Central In. | That's what someone else said about the 20 HP motor, the motor has a tag on with all spec. and it clearly says 1 phase, also another tag on control box clearly says 1 phase also, this motor has start winding's to help get it started turning up to speed so has extra wires leading into motor, I am not an expert but appears to be wired single phase we do not have 3 phase and no converter. It really does not mater the coil I need is to engage contactor. We have rented this bin for 40 years and it looked ancient back then, has worked fine all these years except for some capacitors needing replaced. Who knows how old this thing is, all I know it was one heavy built unit, worth trying to get going. Thanks | |
