will an agleader Kinze planter monitor module do blockage monitoring?
JHEnt
Posted 10/4/2021 17:16 (#9252679 - in reply to #9252442)
Subject: RE: will an agleader Kinze planter monitor module do blockage monitoring?
SW Illinois
You would have to change all the other ones to the population sensors before the PMM will do anything for you as far as I have ever been told. The same issue would exist if you had a KPM1, KPM2 or KPM3 monitor.
Usually with the MUX bus if there are problems it will come back to a wiring issue. Maybe there's some fold point that the harness got pinched in that you didn't notice. It's not impossible for moisture to have penetrated one of the splice points either which could cause issues. That was that systems best feature and worst issue. Just 3 wires for everything.
If you need a KPM2 we have one sitting out in the shed. It hasn't been used in several years since we put a PMM on the corn planter.
