Posted 10/4/2021 06:42 (#9251726 - in reply to #9250624) Subject: RE: JD 317 Skid Steer
Madison Co. Virginia
This doesn't specifically answer your question, but try to get it onto cast iron and relatively close to the starter.
I purchased a 1840 Case, and found the negative cable was attached to the skidloader frame. All starting current had to travel through the engine mounts. I replaced the negative cable and bolted it to the bellhousing instead.
