Wisconsin | something is wrong with the plumbing, or how that shower valve is hooked up, or the valve itself. start with taking the handle off and REMOVING the temp limiter notch ring thingy, or post a photo of what's under there if it's not obvious. It could be a pressure balancing valve that's jammed with a bit of solder, or something else. You should be able to run pure cold water, and the limiter should limit the highest temp it can reach, but that assumes things are hooked up correctly. | |
