Search Forums | Classifieds (20) | Skins | Language
290 Magnum with a 372
caseihfarmer
Posted 9/12/2021 11:12 (#9216026 - in reply to #9215717)
Subject: RE: 290 Magnum with a 372
East Central, Nebraska
yes though it may not be as easy as you think. it will not be as easy as plugging the roof cable into the nav900 but it can be done with the correct cables.
i have not been around the nav900 a lot or the newest trimble displays but back in the previous models of trimble monitors it would just take a cable ran from the trimble display to the roof and the nav box would need to be reprogrammed to recognize the trimble display instead of the cnh display. the system you have can be configured a couple different ways. as i understand it, it could be utilized as the terrain compensation device or you could still use the nav box like it was done traditionally. if your steering already then your combine has a nav already installed so i would say whatever direction you plan to go you have all the hardware to make it work. i would think your only lacking a couple cables to make it happen.
Edited by caseihfarmer 9/12/2021 11:13
