East Central, Nebraska | i would agree with the above. i had a miller nitro that had sections switches on the hydro lever and i could not use them. i had to use the boom switches on the exboom. i did not like that at all. i think when the switches were on nothing worked. not even if you flipped the ezboom switches one way or the other.
i used the ezboom for swath control only. you could wire them two different ways and each way took a different harness. is it possible you have the harness that uses the raven display for rate but the ezboom for control? also when you got into liquid control with the 500 the unlock situation got a little foggy for me.
when your testing it i would make sure you have it on manual control with the autoswath off or it will not open them up because it knows your not moving and sitting in the same area.
Edited by caseihfarmer 8/5/2021 10:16
