Nebraska Panhandle | I have a EzBoom 2010 hooked up to a Ezguide 500. This spring the boom valves kept opening and closing then finally remained closed. I thought the 2010 went bad so i ordered a new one. Hooked the sprayer up to the old Raven 450 and spayed the rest of this summer with it. Today i put the new 2010 in and the boom valves will not open just like this spring. It shows rate 1 and 2 and the red and tan lines when the boom switches are turned off and on but the spray valves will not open up. Green light is on on the 2010. Tried new harness to the sprayer and different Ezguide 500 and nothing works. Any ideas on what could be the problem?? All wiring looks good and everything looks to be connected as the manual says. | |
