Search Forums | Classifieds (101) | Skins | Language
JD 9230 SF1 Weaving
mocofarmer7
Posted 7/23/2021 09:51 (#9124892)
Subject: JD 9230 SF1 Weaving
SWIL
Have a John Deere 9230 (2008 model) that will run a few passes perfectly straight on SF1 and then occasionally will have a pass where it is constantly searching for the line, weaving 10+ inches past each way. This spring I used different combinations of 1800, 2630, SF3000, and SF6000 and the issue was consistent. I messed around with sensitivity settings and it didn't seem to help much. I've been using the true measurements for the tractor all along but am wondering if a change here could help. What do I need to try next? TIA
