NW IOWA | Thanks, PBD . that explains why I could not do what I wanted. I can understand why they did it not spraying till 0.7 but it would be nice if you could just spray by hitting the over ride widget. Another ? this machine has 120ft booms with high volume pump and it wont spray with a steady pattern when I am only doing around 20 ft or less. It will if I go and shut done the yellow vavle down to just open, I run it at the 2 oclock position otherwise. Im thinking its the big pump cause my last two had the standard pump and never had an issue. Not enough back pressure? Thanks again for the earlier post. | |
