Search Forums | Classifieds (60) | Skins | Language
Indoor ac ice on evaporator
ksfarmboy1960
Posted 6/10/2021 21:26 (#9052431 - in reply to #9051846)
Subject: RE: Indoor ac ice on evaporator
66524
Probably low on refrigerant.I would not put leak solution in my system.Find the leak and repair. If it is an older system 15 years or older, there is a chance the evaporator or a coil is leaking.Most older coils ran the tubes through steel sheets where the U tubes are brazed in.Over years the coil will develope leaks where the tubes go thru the steel sheets .Coil will have to be replaced if that is the leak source. $700. to $800. job or more.
