Search Forums | Classifieds (123) | Skins | Language
John Deere rate controller problem!!!!
sparrell
Posted 6/10/2021 17:55 (#9052026 - in reply to #9051655)
Subject: RE: John Deere rate controller problem!!!!
chiefillini - 6/10/2021 13:15
Just got a new rate controller from deere a few weeks ago. Currently running a fast 3pt mounted boom, 80', 48 nozzles, 4 control sections. It has a Raven rate valve on it that we programmed into the 2630 along with all other measurements.
Whenever a section turns off in the field my rate (20gal) drops significantly to read 7-12gal/acre. But my spray pattern doesn't look like it has changed. Why is this happening and how do I fix? Sure didn't have problems with rate on our Raven....just got tired of manually flipping switches on tricky fields.
Thanks for any help! I can post pictures too if anybody needs
Do you have a pressure gauge plumbed into the boom to confirm whats going on?
