Posted 6/10/2021 13:18 (#9051662 - in reply to #9050353) Subject: RE: Drill Monitoring
North Central Ohio
I've done some drills that way. Most of the time, I only monitor a couple of rows and adjust the configuration and gain settings to compensate for the rows that do not have sensors. As mentioned...AgExpress for the harness. They can make it so it plugs directly into the STMM. Hardest part is figuring out how to mount an implement switch
