Posted 6/2/2021 08:40 (#9038083 - in reply to #9037020) Subject: RE: 5 hrs later.
SWMN
if the field IQ module is mounted so the wires are hanging out the bottom there is a black ground wire that will eventually pull out of its socket in alot of cases. harness is made so that wire has the most strain on it. suggest to support the wires if thats the case. I have seen it many times with all different modules as the ground is the same place in all of them
