| Are you slowing down to much before shutting off the master or boom switches? If so the pressure will be to low to get a good pattern when you restart until you get up a little speed. In those situations I used to flip my rate switch to manual prior to slowing down. I would then start from a stopped position with it still in manual and then flip it to auto after I was up to speed. You can also put the rate switch to manual and hit the increase switch to bring the pressure up before taking off from a stopped position.
Also if I remember correctly there is a minimum GPM number that can be set into the 440. | |
