Kingston,Mi | I purchased a manifold with (3) 344BEC valves on it from Shoup to replace the ever reliable 144 ( can always relie on 1 being stuck) valves I had mounted on my sprayer. No instructions with the valve manifold, so I mounted and plumbed it, then transfered the wires to it. No response when I switched the valves on with the Microtrak 3000. Tried several different trouble shooting directions, finally broke down and searched with Bing for 344bec wiring instructions, about the 3rd suggestion was a thread on NAT had the easy to understand answer from KRK. Spent today wiring in a switched constant 12 volt positive source and plugged everything in as directed and it works. Thanks again NAT and all of the contributers. | |
