| I really like Stanadyne products. For general lubricity, use the purple labeled bottle of Lubricity Formula. For winter anti-gel, use their green labeled bottle of Winter 1000. Of course, when treating your fuel, you should find out first what additives were already added. There are conditioners that demulsify water (expels/separates water and fuel) and the other type emulsifies water (en-capsules the water molecules with a lubricant and carries it with the fuel thru the injection system). Personally, i would rather drain the water off the bottom of the tank than to send it thru the injection system and risk some molecule of water to turn to steam in the injector tip and blow the tip off. Don't mix the two types of conditioners. I have been told if you mix the two types of conditioners in your fuel, they neutralize each other and neither one will do its job.
Lots of free advice out there, so decide what works best for you, and what you want to use and just go do it. Don't worry about how everyone else does it. Or what I use, for that matter !
P.S. As an added thought....... It seems to me that Stanadyne is nearly the only company that builds fuel pumps, injectors AND fuel conditioners ! They should know what is needed ! | |
