| +1. If you can, unhook the discharge line from the compressor and adapt shop air to that line. That way you can air the truck system up without the engine running, and you can hear.
Also, while doing that, soapy water sprayed on that line and any others may be a big help. I have seen that line the above poster is talking about leak faster than the compressor can make air at an idle. Check the small lines to the air governor as well. Also, make sure the purge valve on the bottom of the air drier is not leaking. | |
